More likely fluorosilicone elastomers - viton is common for O-rings, but anywhere you use a bellows-type diaphragm, a large flat piece of elastomer that has to move like in a pressure regulator or fuel flow controller (present in some form on all Bendix or AFP injection systems, and carburetors), the material of choice since 1987 (if memory serves) to replace standard rubber has been a flourosilicone variant. They don't care about ethanol or higher volatility fuels. I know that AFP is/was using fluorosilicone for fuel controller rebuilds, as I had them overhaul my (used) Bendix injection system on 2015 as I was assembling my FWF and that's what went into it.
These elastomers became the de-facto standard in the automotive world after the problems with natural rubbers became more apparent following the mandate for unleaded gasoline in the late 70's. The unleaded fuel has to be a slightly different mix of hydrocarbons to get the same anti-knock rating without the lead, and that mix was a little less friendly to natural rubber. The same problem is encountered today with ethanol mixes. I doubt you could even find a rebuild kit anymore with natural rubber diaphragms for anything larger than a lawn mower - and that, by the way, is precisely why small engines don't like fuel with ethanol.
And yes, I am that old. I lived through that, and remember it well.
