Craw
Hello,
I am trying to install my new whirlwind 330 series 2 blade constant speed propeller onto my factory new Lycoming YIO-360-A1B6.
The Whirlwind instructions clearly state that the drive lugs must protrude the flywheel surface by between 0.18” to 0.20”.
The drive lugs provided with my engine only protrudes ~0.14” so just shy of the baseline requirement. I have noticed that the two drive lugs meant to be flush are recessed by ~0.04 which happens to be the dimension that I am missing to meet the requirement.
The flywheel is is fitted with the O aligned with the O on the crankshaft. I can’t find anything causing interference with its fit..? Should I order new lugs or a new flywheel? What could be causing this issue?
Thanks for your feedback,
