I guess different folks have different luck - I’ve been using nothing but Rapcos for close to 20 years - replace them on each plane maybe every third annual due to wear - never had a problem.Rapco pads are terrible.. but their disks are ok.. I started using Mcfarlane brand Disks and pads, very nice stuff. It’s sold by Mcfarlane and Spruce under the brand APS.
I too have been using rapco linings for a very many years. It seems that they may have changed the "recipe" recently because the new linings look different and literally crumble with normal use. There's at least one thread here discussing the new lining materialI guess different folks have different luck - I’ve been using nothing but Rapcos for close to 20 years - replace them on each plane maybe every third annual due to wear - never had a problem.
Replace Every 3rd annual, wow! I’ve been running Grove for 20yrs, never replaced the rotors and seldom need pads, and I don’t baby my brakes.I guess different folks have different luck - I’ve been using nothing but Rapcos for close to 20 years - replace them on each plane maybe every third annual due to wear - never had a problem.
And on our Grove-equipped Tundra, which has been flying for right years and 500 hours, we have yet to replace a brake pad. I agree - the Groves are great!Replace Every 3rd annual, wow! I’ve been running Grove for 20yrs, never replaced the rotors and seldom need pads, and I don’t baby my brakes.
Also used them for years. Last set crumbled into pieces at 30 hours. Never again.I too have been using rapco linings for a very many years. It seems that they may have changed the "recipe" recently because the new linings look different and literally crumble with normal use. There's at least one thread here discussing the new lining material
Thanks! This is the first I'm hearing about APS "BlackSteel" brake discs: https://www.apsbrakes.com/blacksteel-brakes... I started using Mcfarlane brand Disks and pads, very nice stuff. It’s sold by Mcfarlane and Spruce under the brand APS.
Jherzog,Thanks! This is the first I'm hearing about APS "BlackSteel" brake discs: https://www.apsbrakes.com/blacksteel-brakes
I guess I should have titled the thread Cleveland vs Rapco vs APS. It looks like APS are the same price as Rapco. Any other thoughts on going with APS for replacement discs?
I have the APS.. they are really nice.Thanks! This is the first I'm hearing about APS "BlackSteel" brake discs: https://www.apsbrakes.com/blacksteel-brakes
In buying new hardware to mount my new discs, are there alternatives to using genuine Cleveland-branded hardware to mount the discs?
For genuine Cleveland, 6 bolts ($18.50 each), 6 nuts ($4.35 each) and 12 washers (at $19.60 each!!) comes to over $370 from ACS. Ouch!
Also check out the new wheel nuts that we all should be using.
and Mobil SCH100 grease.
Thanks Dan. So why would ACS stock "genuine" Cleveland washers at $19.50 each when the generic AN washer is 9 cents apiece?
I agree, any decent grease will do, and sure, the Nylock nuts we’ve been using for 50 years will work.. but Cleveland put out an updated PRM to use the newer reduced size metal lock nuts, and they call for 100SCH grade. It’s just easier to use the newer nuts that I can get a socket on, and by using the same grease all the time, I can regrease without completely washing away the unknown..It's just AN hardware.
If you don't have one thread showing above the nylock.
Burn me at the stake, but it's a wheel bearing. Nearly any decent grease will do.
Mcfarlane sells APS disks and pads.. good prices..Where did you guys get your rotors? I see them on Spruce for $245. Quite a jump. Does APS make any?
I shop Air Power often. $245 each. Do you have a link?Air power inc. sells them for $195 Free shipping
I went with APS rotors and pads, which weren't even on my horizon until I started this thread -- thanks VAF. APS rotors are here on ACS: https://www.aircraftspruce.com/menus/lg/brakediscs_aps.html.Where did you guys get your rotors? I see them on Spruce for $245. Quite a jump. Does APS make any?
Ok. They're $245 on Air Power. I was hoping somebody knew something different.I typed the rapco part number into the search bar on airpower website. I don't have the part# handy
