OK. I was cluttering up someone else's thread; a superpower of mine. Assumption = Permanent Magnet motors had constaint counter-torque. Response provided below.
So, is the definition of a PM motor wider than assumed? Do the rotating PMs induce a poles in the stator (see comment above about zero parasitic load)? Is it self exciting? Would seem to be work counter to efficiency. Can anyone with knowledge of the various PM motor types share such?
Be insulted that an ME is stepping blindly into your briar patch. Please inform.
So the MZ gens have constant counter-torque loads once enabled? This is different from my assumed and witnessed characteristics of the PM motors we utilize in our industry which don't require any electrical input and have a constaint torque/counter-torque balance. That loading/losses are constaint regardless of duty/load. They are required for starting power plants (critical systems, back-up starting generators, etc.) when no power from the grid is available; important because Texas tries hard to collapse their grid every couple of years.Nope. The MZ just runs the 3-phase generator coils open-circuit when the regulator is not enabled, so no mechanical load. Yes, the generator is making whatever dozens of volts thanks to being permanent magnet, but because there's nothing attached across the coils, no amps are flowing, and therefore zero work being done (watts or HP, same thing).
In the case of this MZ-60 TR, according to your logic, we'd have 800-ish watts, which is over 1 HP of parasitic loads. On my iron bird with the 1-cyl gas engine, 1 HP is a significant load and would be obvious in the engine sound if the generators were pulling that. When connecting a 60A load as I did in testing, you can definitely tell that the generators are pulling engine power, but no drag when the regulators are turned off.
IIRC, 'Old school' PM generator regulators would regulate by varying a shunt across the output, so then you have parasitic load all the time as you say. Bill J's regulator design is the secret sauce that enables the no parasitic load when turned off.
Also, you can demonstrate your "counter-torque" by taking one of Bill's generators without the regulator attached and spin the shaft by hand. Then tie all 3 generator wires together and try to turn the shaft. You won't be able to.
