7StarsAero
I'm New Here
I have two factory built RV12s the the 912ULS engine. One engine has about 900 hours on it. The other has close to 1600. On the last inspection I found a crack on the 900 hour engine mount. It was on the left side tube just below the upper engine support arm. Its difficult to tell from the pictures, but the crack wrapped around the tube about 230 degrees and travels back and up around the tube, with the lowest point of the crack being on the front side of the mount. Now, I have found another crack on the higher time engine mount. It was spotted while the bottom cowling was off and has formed within the last 50 hours (this mount was checked 50 hours ago in this exact spot by myself and a second mechanic). This crack is in a similar area, located on the left side tube, but on the bottom engine support arm.
I have seen one other similar crack on this forum from sometime last year. I am wondering if anyone else has experienced cracks like this. Having two aircraft at vastly different engine times experience similar cracks within 100 hours of each other is concerning. If anyone has any suggestions or experience with these cracks, I would appreciate it. I am concerned this is only a symptom of a bigger problem and not the actual issue. That being said, both of these cracks are near heat effected areas of welds, so it could just be poor heat treatment.
Declan
Declan
