At the risk of making a fool of myself (doesn't take much), I am running into a problem which hopefully is user error.
Has anyone else after cutting top and bottom front cowl to the scribe lines seen that they are not the same size in order to form a smooth fit?
This is for the EXP119 engine, so the top cowl is the regular RV-14 and the bottom is the newer one. The bottom cowl is 1/4" smaller so there is no way for it to be fit properly or at least not that I can see without some surgery here. Any hints?
The red line I drew indicates that it is flush on that side, but I put small red marks where it doesn't line up and on the opposite side of that flush section it is 1/4" too small.
