enigmakv
I am deep in learning about my new (to me) RV-14A. Not being a builder and starting from square one does come with the challenge of learning the airplane and finding detailed information. This post will be about the flaps system on my plane with multiple questions.
1) The flap actuation switch is a toggle switch with a flap-shaped switch cover. The problem is that the toggle itself ROTATES. This means that the switch cover rotates as well making the flap-shaped cover end up in any position from normal to vertical and I find it distracting and annoying. Is there a flap switch available that does NOT rotate?
2) I am away from the airplane and am trying to remember how the switch works but I am pretty sure it has a center "Off" position, a latched "Up" position and I think a momentary "down" which I have to hit multiple times for each flap position. The problem I am currently seeing is that when the flaps are switched to their final down position (in hangar testing) the motor continues to run even after the flaps hit the stop and I have to cycle the switch up to turn the motor off. I worry that in flight I won't hear that motor and remember to stop it and I end up distracted by it. Any idea what the issue could be?
3) It has been difficult for me to find reliable information about the actual flap positions. There are many threads and conversations about "Up", "Reflex", "Trailing" and various numbers for "degrees". When I do searches such as "RV-14 flap positions I can't find reliable information". Where can I find the information about positions, descriptions and measurements for the flap settings/angles etc.?
4) Regarding cruise, is there a position for the flaps other than all the way up? Again, I have read different threads mentioning up, trail, flex. Looking out the window anything other that all the way at the up stop feels like I am flying with flaps at greater than flap limit speed.
5) Finally, I have read threads here indicating different limiting speeds for different flap settings. I have also read 100 KIAS limit for any flaps other than "up". Is there any detailed info out there about limiting flap speeds?
