Throttle cable routing/install advance panel build
nohoflyer
Well I have a nice plate with all the labels for throttle, mixture, etc. with holes for the cables. I have no idea how I’m supposed to mount the cables to this plate.
Help?
You’ll need to drill the plate to the final size depending on the cable. These holes should be fine for your Bowden cables but may need to be enlarged for other cables.
I believe they supply it like this as they don’t know what cables you’re using.
Yea I just spoke to AFP and found out these are pilot holes. I also vented about the lack of documentation for building. They have good wiring diagrams but not so great on mechanical bits.
Conclusion is to call them with questions and there are lots of them.
FYI- if you're trying to mimic the original design you've got the labels printed on the wrong side. Maybe you did this on purpose to make it flush with the rest of the panel?
The one from vans is intended to be recessed under the rest of the panel so you don't have as much problem with the control stick hitting the knobs at full deflection.
Not familiar with what Vans supplies. I built my first extension and it sat flush with the face of the panel, just like the one shown here and the one on my new Advance panel.
RV6 with standard size panel. No stick issues, not even close. Might vary with model and type of panel?
I built a 7A with the stock panel from Van's, mounted flush similar to the OP's. No interference issues.
To assist with the original question, generally the cables are supplied with the appropriate nuts to fasten the cable to the sub panel. Biggest challenge is routing from the sub panel, through the firewall, then to the destination in the engine compartment.
If flush mounting the sub panel is working for you guys, more power to you, but there have been several people who've had issues during their AW inspection because the stick hit the knobs at full fwd/right aileron and the inspector wouldn't sign off on it that way. They had to either relocate the knobs or cut more off of the stick.
Here's a picture of a flush one that I pulled from the internet (I think it might be Jason Beaver's plane?) vs one from my plane in process a few years ago. The last picture is a screen shot of RV7&9 drawing 24.
If you flush mount that sub panel, the knobs are going to be about 3/4" further aft that Vans intended when they designed the layout and control throws.
Like I said, I know a lot of people do it that way, but people shoud at least be aware
Yup
Not to mention all of the builders that have complained over the years about the engine control cables provided in their FWF kit were about 1 inch too short🤔
Help?
I have the same plate. I drilled them to the correct hole size with a unibit. I made a plate on the forward panel bulkhead according to plans but with allowance for the unusual arrangement and secured the cables with adel clamps per plans. I did have to cut the sticks down. I even cut them a second time but maybe didn't need to. Wait until your wings are on and the control stops determined before cutting the sticks. The stops might make it unnecessary.
Note: The Van’s demo 9A stick hits the mixture control. My FWF supplied cables barely made it using the firewall holes per plans.
View attachment 105236View attachment 105237
Helpful thx.
Advance supplies the bracket as shown and they do a lot of panels. I’m sure they could screen the reverse side and folks could flip the bracket if needed.
When I built the 6 there were no plans for controls on the panel or panel extension, no cable routing recommendations, etc…..
I rolled my own and then measured for cables.
Here is my DIY bracket from 20 years ago FWTW.
Curious question. What’s the length of your stick from the top of the socket to the top of the grip?
Some of these grips look really long compared to my simple Ray Allen. IMG_0821.jpeg
I don't have the exact number in front of me, but I cut the same amount off the stick that my Tosten military grip added for a net zero.
