How tight should the upper and lower cowls slide together at the nosebowl (RV9)? Should they actually slide together with friction, or should there be a slight gap in everything except where the screws go through in the inlets? My fit is the typical Van's fiberglass fit, so I'm going to have to do a lot of sanding and then re-fiberglassing, but I'm not sure what to target for the fit. Likewise, for the horizontal junction and firewall fit, is 1/16" gap between all parts about right, or do I need a little more?
