This isn't the first time this has been done, nor will it be the last.
I sourced these from Amazon for ~$17; they're extremely loud (+120dB) and reminiscent of a 70's Lincoln. Sure beats yelling "Clear Prop" and hoping that someone hears you.
Wiring was dead simple; High current power and relay power from always hot buss (fused) at the battery, relay + connector mounted on the front of the battery box, horn switch ( [on]/off located on the panel by the key switch.
The horns are mounted to a single piece of AA6 0.75"x0.75"x0.063" on one leg, the other leg has two MS21919-WCH12's which hang off the adjacent motor mount tube.
"beep-beep"
"beep-beep"
