I have a RV6A with a O-360 A4M engine, MA4-5 carburator and whirlwind fixed pitch prop.
The engine runs normal in flight or high RPM on the ground.
My problem is the mixture setting at low RPM. Even with 6 turns in the mixture screw in the carburator I still don’t have any RPM rise when leaning at 1200 RPM on the ground.
I removed the carburettor I had and installed an overhauled unit but I still have to use 6 turns on the screw to have a reasonable smooth idle but not rich enough to cause RPM rising when leaning.
I 3d printed a plate to attach to the bottom of the carburetor and connected that to a regulated air pressure source (see photo). I injected 10 psi and cross checked that value connecting a manometer to the manifold pressure line in the engine. Spraying soap on the intake system I couldn’t find any leaks.
Suspecting I could have a hidden leak inside the sump, I swapped mine for a new one but it made no difference.
Now I am running out of ideas. Does anyone have any idea to help me?
Cheers
Cheers
