Tie down ring drag penalty
I installed a set from the aero garage. TAS is the same as before install. They are smaller than the vans tie-down rings.
Take them out for your next cross country.
Mine are installed for aero flight. 😂
Put them at 90 degrees to your direction of travel. The Venturi effect and Mr Bernoulli may have you going faster😉
Please don’t take me seriously.
Cheers DaveH
Dang, I was thinking a pressure recovery fairing like wheel pants…..
My wing tie down eyes live in the overnight bag with the intake plugs and pitot cover.
I manufactured an airfoil shaped tie down fitting for the tail. It stays mounted and has served as a tail skid twice (Don't let two people step on the boarding steps at once).
I've made, and still am, in the process of making many aerodynamic refinement on my steed.
Tie-downs hanging in the breeze are a sore sight, maybe even an insult to any professional aerodynamicist working at designing the most efficient airframe possible 😉
The penalty must be heavy, probably in the region of 0.782 KIAS for a tail mounted one, 0.981 KIAS for a single wing mounted one, and 1.36 KIAS for one on each wing, at standard cruise speed...
The penalty in fuel burn must be enormous too, but I'll leave the calculations to the more educated readership here.
Sitting on the ground, a tie-down(s) equipped RV looks like 20 knots slower to my untrained eyes 🤓
Tie-downs hanging in the breeze are a sore sight, maybe even an insult to any professional aerodynamicist working at designing the most efficient airframe possible 😉The penalty must be heavy, probably in the region of 0.782 KIAS for a tail mounted one, 0.981 KIAS for a single wing mounted one, and 1.36 KIAS for one on each wing, at standard cruise speed...
Me thinks you might be exaggerating. You need to adhere to MY philosophy, As I've told my Wife millions of times. "I don't exaggerate!"
I see 2+ knots penalty (I want to say 4 but that seems absurd…) using the standard Vans tie down rings. I replace them with an appropriately sized screw.
Well, obviously it's not zero, but it's so small that I don't think you'll ever be able to tell a difference in airspeed.
Stuff like this reminds me of when glass cockpits first became a thing. Suddenly we had a whole rash of headaches in pre-delivery where people would squawk that with the power levels exactly parallel the EPR or % torque or whatever was 70.0 on the left and 70.1 on the right, and could you pretty please re-rig that?
I think I flew with that guy!
This thread made me realize that I fly with mine installed all the time - me, who buried as many antennas as I could under fairings and canopies...
I think my reasoning from the git-go was that the speed reduction / increased travel time was likely less than the extra time required at departure and arrival to remove / install the rings prior to hopping into the rental car and completing the actual door-to-door trip.
I think you may be off by a decimal place in your estimates...they are likely a bit high.
Link requested please.
Not the OP, but here’s the link.
The tie-down loops are Titanium, so they probably ADD 1.69 KIAS…
Seriously, they look very cool, and are currently sold out.
No need for that, you can gain back the drag penalty and more by adding bling. Everybody knows that parasite drag can be reduced because air won't stick to chrome pushrod tubes or flame paint jobs.
I hear if you anodize the aluminum parts this works also...
Mel you push the envelope but there’s no way I could ever imagine you exaggerating.
Here’s one for the guy with a 3D printer trying to figure out what to print. A pressure recovery slip-on. A slight convex curve that fits inside the tie down ring so it snaps in place and the trailing comet tail for pressure recovery. Easy on, easy off, but they stay in place. Be sure there is a drain hole in the bottom.
Pardon the crude drawing but it makes seeing what’s in my imagination easier.
I'm a liar. That statement is a lie.
Feed that into your AI! :LOL:
A tied down airplane is really slow. Maybe zero knots. So are the rings a speed penalty or is that a lie? . :unsure:
Not if there is a wind. A plane tied down into a 20kt headwind will have a 20kt TAS. Again you fibbed to us.
Dont forget the speed bonus you pick up with the checkerboard rudder! :)
I think the airspeed difference is about the same as the weight and balance difference, particularly since they are located on the CG and the moment arm is zero, 0.1 lb time zero distance is zero moment.
The shark’s mouth is worth several knots. That small edge made all the difference for the Flying Tigers in their dogfights against Kates and Oscars. 😉
And what would the air speed be with a 20 kt tail wind?;)
Still 20, just backwards since the air is moving over the plane at 20kts. I would be worried that the gust lock might fail and ruin my checkerboard speed rudder. Might even be more if there was a fresh coat of speed wax on it.
I guess I’ll never get somebody to print out a set of slip on speed fairings to test and send me a set cuz it was my idea to give them something to print on that fancy new 3D printer and they are looking for ideas.
WOW, just think if each fairing was worth 10 knots, just think what you would gain if you did the OAT post, the transponder antenna, the fuel tank vents, com antennas, rudder horns, exhaust pipes, and canopy latch lever. Holy mackerel Saphire, that’s at least a 100kts. It would be so slick I’m not sure I could slow it down enough to land it unless it had a drag chute.
it’s not worth the penalty of getting to your destination and can’t find your tie down rings.
To put it in perspective let’s assume it’s a knot or two. Flying 100hrs/year at 8.5gph and $5.50/gal and about a 1% increase of efficiency you’re gonna save about $50/yr. Meanwhile you’re installing and uninstalling them dozens of times. The minute and a half you saved on the XC will be negated while you fumble around looking for your tie downs and the time it takes installing them.
For normal flying use this is kinda nonsense
I am sure this could be accurately estimated through the formulas in Fluid Dynamic Drag from S. Hoerner, one of my favorites. I know he estimates the drag from one of those old ring antennas from days past. I do think however there are lower hanging fruit, for instance the tailwheel. Watch our newsletters for an effective, affordable solution under development in the AeroSouth Skunkworks......greetings to RVAtor Rob V at the real SW.
It’s going to be a fraction of a knot and likely less than the instrument error…
I typically leave rings in. Now Im wondering what the speed penalty is.
What about a flat airfoil shaped blade with a hole for tie-down, and machined threaded shaft that goes up into the wing, and for alignment since the threads won't ever be perfect when tight with blade to align with airflow, the airfoil flat with hole could swivel freely to aid in tie down alignment and flight alignment which could be different. Yes, a lot of engineering and fabrication involved, but isn't that what we enjoy? Can't wait to see if anyone puts this idea down on paper, and posts. Thanks.
Yes, I bought a set of these, in black. Looks good and gotta be worth at least .01 Kts :) In addition, I have the fairings for the fuel drains and the fuel vents. Wicked fast. LOL!
Great winter project , until I come up iron clad solution , I’ll just keep Flying WOT & hangaring my queen !
Great idea. Look out grinder, here it comes. Plenty of steel there to make this happen. Since I reshape HSS lathe tools as needed, it would be a walk in the park to reshape the ring. I need to paint them so why not tweak the shape before painting. Others will drool over the 20 knots gained…. Now I got to dig out the rattle can with the correct color.
I was being generous, you’re probably right so make that $8/yr savings 😂. I’ll skip a Starbucks coffee and leave my tie downs attached
$8 hmmm, you must be enjoying one of those fancy high calorie liquid desserts disguised to resemble a cup of Joe. If you skip those, the reduction of weight penalty will offset the drag penalty. 🤣
