Thumb typing m, pardon the brevity.
Where did you locate your air temp probe? Heeding the install manual regarding engine/exhaust heat avoidance, would like to put it at the access panel in either wing for access/install/inspection purposes. The GTP only come with 10 ft of lead. Obviously a home run to the ADAHR would be desirable to help keep the signal error down.
What location and/or what compromises were done? Did you get acceptable readings? Thx.
