RV8, IO-360 (actually O-360 which was converted to fuel injection by the builder) Catto 3 blade FP prop.
Taking off yesterday, the airplane seemed a little sluggish, not performing exactly like I'm used to. Looking back, I realize now I was about 50-100 RPM low at full throttle for T/O. Fuel pressure normal, MP normal, mixture full rich. With the Catto I usually see 2100, 2150 as I get rolling static TO RPM. I was about 2050 by the time I noticed.
Once I reached cruise, the acceleration to cruise speed / RPM seemed a bit slow- then when I began the leaning procedure, it was definitely not behaving as usual- EGT would not reach the "normal" range (1300 ish peak) before the engine became rough. I tried several things, Alternate air (no change) Mag check (functioned properly) boost pump on or off, no help. I kept attempting to lean, back to full rich and tried several times. this was at 7500'. After several attempts, the engine stumbled, then seemed to return to normal operation, but still could not reach the EGT I'm used to seeing.
CHTs were normal, each about 300 degrees which is in line with what I usually see.
30 min later I'm back on the ground. Idles fine, runup at 1800 RPM Normal. So its only a full throttle or high power setting problem.
I let her cool down and pulled the upper cowl looking for the obvious stuff. Plug wires all tight, no fuel stains anywhere or exhaust leaks, in short nothing obvious. The one thing I found, is the #2 injector (the forward left cylinder where the injector is exposed to cowling opening) had alot of blue staining and when I wiggled the fuel line (spider to injector) it was slightly loose at the injector. I tightened it, cleaned it up, ran the boost pump a couple of times and saw no leaking.
Took off the next morning and all was back to normal. The other part of the puzzle, the day before the flight in question, I flew about 35 min of acro, so alot of time running around richer than normal. So possibly a couple of dirty plugs? Plugs were replaced 50 hours ago and haven't been out since.
Airplane is new to me with about 40 hours in the last 3 months of me getting to know it.
I'm aware of the Lycoming SB regarding fuel injectors, but this seems to be a concern with the horizontally installed injectors (mine are not horizontal) but could possibly do with a cleaning, not sure when it was done last.
Could the loose line have caused the running issues I had? This was the only injector with the blue stains, I understand there's a bleed hole on these injectors so it's not unheard of to see fuel staining? But the other 3 are clean.
Looks like a little solder has chipped off of the fuel line, should this line be replaced?
