I did data reduction from the OP EFIS pictures. He did one single test flight at 7500 and 10500. At each altitude, he flew the same heading. There was a significant cross wind component during the flight and this made accurate IAS more difficult. The OP needs to read up the IAS calibration and to a 3-leg calibration run with constant altitude, and preferable in the very early morning instead of 2PM in the afternoon.
MP is consistent with the operation at 10500 at 19in, and at 7500 (21.8in)
Other significant observation, the airplane was not run at high power. This was economy cruise power or less. The Min CHT was in the range of 304 - 305deg at 7500 . The min CHT at 10500 was from 296-319. The engine was not run very hard. To get the high cruising speed, the OP need turn up the propeller RPM
The fuel burn was low but it wasn't out of line for lean of peak operation. However, the OP kept on fidgeting with the fuel lever and the propeller RPM lever and the fuel burn values were not consistent with the goal of calibration testing. The Fuel burn at 10500 started out from 11.3 gal/hr and dropped to 7.8 gal/hr. This is a wonderful number for fuel saving but not for high speed cruise. The test should be done with a constant power and fuel setting.
From my little RV8, the flight was almost a year ago, at 10,500 (11200DA), TAS was 172, fuel burn 8.8gal/hr, MP 19, CHT (360-374), OAT 38, RPM 2690. This was a fixed pitch prop and there was more speed if I have a constant speed propeller.
So at much lower OAT, I was getting a lot higher CHT temp. The OP engine was at low CHT, low power economy cruise mode. The airplane needs to be run at higher power setting to realize the higher TAS
Here is the spreadsheet I recorded from the OP screenshots. I separated them into two sections, 7500 and 10500 feet and the rows are ranked by time.
