The absence of jam (shear) nuts on the connection between the rod end bearing and the pushrod, as well as the excessive number of threads coming out of the stop nut should have been clues to anyone with experienced eyes to look more closely.I see now, the "eye" should be in the vertical position in the lower picture, so the eye was able to rotate and both sides have that issue. If it was like the top picture, the eye holder can only rotate to the stops on the eye, so it can rotate, but not continuously, and that's why the threads are so different in length. Unless you really look and notice the eye position and the excess bolt length, hard to spot in just a quick glance.
I am grateful for the process we have here in Canada. You need at least two inspections by the MD-RA (Ministers Delegate - Recreational Aviation) before you get a C of A; a pre-cover inspection where they look at every nut, bolts, rivet, etc before any structures are closed up; and a final before first flight. Your airplane has every cover and panel removed for the final inspection but otherwise ready for flight. I just had my final done last month and the inspector (who is also a member of these forums) found a list of things my eyes just didn't see anymore ... including several jam nuts not tight, possible interference problems, etc. The inspection itself can take a few hours to a whole day and only a small part of it is the documentation verification (although that is thorough as well)I keep hearing stories about DARs that only check to see if the manufacturer, model, and S/N on the registration match the data plate on the tail of the airplane. And then there are DARs that carefully go through all of the control linkages among many other things and make sure everything is proper, safe, and airworthy. I'd rather have the latter kind of DAR.
YEP! It's called "Murphy's Law"!When this came up originally, I had these comments:
If a part can be put in backwards, at some point it will be.
I remember a number of years ago (2013) someone installed the rate gyros in a Proton rocket carrying three GLONASS satellites upside down.YEP! It's called "Murphy's Law"!
Don’t ever depend on just one set of eyes (other than your own) to make sure things don’t get missed. Please plan on having MANY folks (EAA chapter members, other builders, EAA Tech Counselors….) look over your project long before your DAR gets there. A DAR will probably get to spend a couple of hours, and while my focus is always on the “killer items” when I inspect, there are many other things that you can get wrong that others will catch. In other words, don’t put ALL your faith in the DAR - ANY DAR!I know for sure that I couldn't make this particular mistake. But, I'm also pretty confident I've probably made dozens of other mistakes during my build. I sure hope my DAR takes a VERY close look at my airplane before signing off on it.
Thanks for the feedback PaulPlease plan on having MANY folks (EAA chapter members, other builders, EAA Tech Counselors….) look over your project long before your DAR gets there.
Or simply understanding how a heim joint is designed to handle load would make it obvious that the forces were in the wrong axis. Force is trying to pull the ball out off the joint vs pulling against the bearing surface. Heim joints are designed for radial load, not axial.The absence of jam (shear) nuts on the connection between the rod end bearing and the pushrod, as well as the excessive number of threads coming out of the stop nut should have been clues to anyone with experienced eyes to look more closely.
Yes many personalities don’t take criticism well and this trait often prevents them from getting good feedback. Often not a big deal when one is highly skilled, but very unfortunate when skills are limited.I know a few builders at the local airport who are somewhat secretive about their RV project. The hangar door was kept only slightly open, allowing just barely adequate ventilation. Some even parked their big trucks in front to prevent spying eyes.
I took it differently. After moving the project to the airport, my hangar doors were wide open, everyone was welcome, opinions included. I just wanted as many people looking at the airplane when it was wide opened and hopefully someone could spot errors that I didn't see. The hangar visitors definitely provided many good advices. I keep the same habit today, the hangar doors are always opened except when the sun light was too uncomfortable.
This is so true and even highly skilled builders can look at something and not realize there is a problem, for some strange reason they are also blind to obvious mistakes that others see instantly.Yes many personalities don’t take criticism well and this trait often prevents them from getting good feedback. Often not a big deal when one is highly skilled, but very unfortunate when skills are limited.
So true. Even experts occasionally get target fixation.This is so true and even highly skilled builders can look at something and not realize there is a problem, for some strange reason they are also blind to obvious mistakes that others see instantly.
That's how my AW inspection went, too.the inspector (who is also a member of these forums) found a list of things my eyes just didn't see anymore ...
I definitely see your point, but I wouldn't necessarily attribute shady motives, though. Even well-meaning visitors can be an unwelcome interrution when you're working on something that requires concentration or is a time-sensitive process. Or perhaps they have limited/non-flexible time available for building and visitors mean lost progress for the day. Parking the truck to block the entrance is a more subtle "do not disturb".The hangar door was kept only slightly open, allowing just barely adequate ventilation. Some even parked their big trucks in front to prevent spying eyes.
A story in that regardI definitely see your point, but I wouldn't necessarily attribute shady motives, though. Even well-meaning visitors can be an unwelcome interrution when you're working on something that requires concentration or is a time-sensitive process. Or perhaps they have limited/non-flexible time available for building and visitors mean lost progress for the day. Parking the truck to block the entrance is a more subtle "do not disturb".
I have a slightly different perspective. This is experimental aviation; flying machines built from scratch or kits. A kit with instructions in this case. Vans does a really good job of making the build instructions pretty easy to understand. That being said, even the simplest of instructions can be misinterputed. The plans are designed so anyone, with very modest talents can assemble the plane so it will fly, and actually fly pretty well. But, they are still flying machines, ones that can be unforgiving of errors.The chin waggers can get annoying, but sometimes the open-door policy pays off! A while back, we had a new hangar tenant stop by when he saw our project under construction, and it turns out that in addition to being a very nice guy, he is a seriously talented welder (works on nuclear submarine construction). Now he's helping us modify our exhaust!![]()
