Has anyone adopted the Charles Lindbergh P38 engine management techniques of very low rpm and over square manifold pressure? I have been experimenting with this in my RV6A with Lycoming O-360 and Hartzell CS prop. I have tried as low as 1800 rpm and 21” mp. With max leaning. I only do this above about 4500’ alt. Below is a chart from Lycoming with acceptable limits.
The advantages are many from running over square at low RPM.
1. Max efficiency for engine, propeller, and airframe. (Drag increases at the square of speed). Most efficient rpm for prop is about 1800.
2. Lower CHT and EGT. Remember, heat is the enemy. Less wear on internal parts.
3. Less stress on engine and prop. Rotational forces are reduced. Friction (and the heat it makes) is reduced.
4. Quieter. Both airframe and prop make less noise. Making noise and turbulence requires energy. And noise is uncomfortable.
5. Range increased (I’ve seen fuel flow as low as 5.5 gph)
Would like to hear from anyone who uses this, and those who have good reasons not to.
John Dill
John Dill
