In our little VAF world, we sometimes mistakenly think we have a broad view of activity in the community and are seeing valid trends. The reality is that regular posters on VAF are a small slice of the community. Sure, for bigger issues like PP problems or sticking valves, that small slice is enough to have the issues emerge, because the issue %age is so large. But for more narrow issues (lets say <1% issue rate), our sample size is just way to small to make claims like EVERYONE ELSE is not having any issues.You are missing the point. Statistically speaking, if there was a systemic problem with the VPX, you would expect to see more failures throughout a large cross section of users yet this one user had two consecutive failures in two separate units.
Right now I am using the Aerosport switches. It is silver contacts and many people use them without issue for the VPX. My decision is mainly because I don’t want to have to go through this again. It’s 20 amps so it will work fine for an old fashion cooper avionics bus.Your choice, but really the right switches are reliable as heck. Which ones are you using in your airplane?
Problem with this is, you never know if one side stops working and then you’re back to square one ( a single pole switch).With the VP-X it is also probably worth using a double pole (DPST) switch with the two “poles” wired in parallel. That’s what I am going to do.
Forgive my ignorance on this, I haven't even pulled the first rivet but trying to learn as much as I can to prepare.. including what power options I have available.I just made 3 flight today totally 2 hrs. No issues at all. I am certain it is the switch. I will investigate the ground wire of this switch and the switch itself. Right now I am just trying to get hours on it with the switch bypassed to get the most accurate result. A gold plated switch is not my fix for this though. Keeping avionics off the VPX is the fix that will make me the most comfortable with the install. I feel that any switch function needs to be looked at with how much of an emergency it will create when the switch started to cause the VPX to act up. That’s how I am assessing the risk now at least. I am even considering having a separate switch for the 355, that way i have switch redundancy for my second navigator. I have to think more about that.
This is a very valid observation in my opinion.Forgive my ignorance on this, I haven't even pulled the first rivet but trying to learn as much as I can to prepare.. including what power options I have available.
If you believe the failure is the switch itself, how does moving the critical avionics off of the VPX on to their own direct circuit - presumably still behind some sort of switch - fix the issue? I understand removing the VPX as a potential point of failure, but you're still going to have a switch in there someplace and you at least assume this is your current point of failure.
I can see how you can get some level of redundancy by using mulitple switches for each critical components to minimize loss, but couldn't you do this with the vpx too? I'm not familiar without how many switch inputs it has so maybe not.
It’s because the switch with silver contacts and no voltage used for the VPX tend to get dirty and I could get the same problem again. Many others have not had that problem with these switches but it looks like I have. There has been some reporting switch issues through the VPx. I am just trying to eliminate that problem. I could try gold contact switches but then I have a lot of work to redo all the switches. This change will allow me to add a back battery to my avionics bus as well in the future. I still have testing of the current switch to do but that is where I am at today.Forgive my ignorance on this, I haven't even pulled the first rivet but trying to learn as much as I can to prepare.. including what power options I have available.
Pretty sure my AML-34 switches supplied by Stein have silver contacts. Between the 2 VPX's over 800 hrs and 6 years, no issues. Maybe I'm just luckyIf you use high quality electronics grade switches, the chances of a switch failure are very low IMO. The switches on a VPX carry no current at all, they are all active-low, meaning that they ground out the circuit to tell the VPX to enable the device(s) that switch is assigned to. Using a high current capable toggle switch isn't a great idea when you just need a very reliable logic-level signal toggle.
Here's the ones we (and many others) chose. I believe (check this tho!) that the ones Stein sells have gold contacts.
AML-34 Illuminated Rocker Switch - Steinair Inc.
Rectangular DPST Rocker Switch rated for 15 amps having a single independent lamp circuit. Both AML 12vdc & AML 24vdc LED lamps draw 15ma (0.015amps) at their rated voltages. Both AML 12vdc & AML 24vdc LED lamps have internal current … Readmorewww.steinair.com
You will see them in the AML24 sheets. AML24 are the lower current version but the same form factor as the AML34.If someone has a spec sheet showing Honeywell AML series with gold contact would love to review. Thanks !
This is unnecessary. The VP-X works with any and all switches.With the VP-X it is also probably worth using a double pole (DPST) switch with the two “poles” wired in parallel. That’s what I am going to do.
The VP-X is designed to work with all types of switches, you can use anything you want. The VP-X applies a small amount of "wiping current" that effectively cleans the switch contacts as they are used.Pretty sure my AML-34 switches supplied by Stein have silver contacts. Between the 2 VPX's over 800 hrs and 6 years, no issues. Maybe I'm just lucky
VPX has been doing this for quite some time, seems they would recommend gold contacts for switches if it was a factor but that of course is speculation. Stein builds hundreds of panels with VPX, seems they would also specify gold contacts if it was a factor. VPX does recommend gold plated connectors, but I have never read they recommend gold switch contacts.
and… off memory the Dynon Manual says not to enable current fault for that reason.FWIW, one data point.
I had the fault detection enabled on the Dynon Heated Pitot...
Since that device cycles on/off, VPX detected a current drop and tripped the circuit...
Disabled the fault detection and voilà !!! No more tripped circuits.
Other than that, my VPX is working as expected.
Best of luck in resolving your issue.
Can you elaborate on your the flap issue you had?? I am experiencing a flap issue now with my VPX Pro.Im for sure not the one with elect knowledge but I fought a conflict with my VPX and G3X and the flaps for about 6 months. Josh and Nick were great trying to help me out. I never talked to Chad at VPX but I did go to Midwest Panels because the3y are close to me. Still no luck. I was ready to remove the flaps from the VPX wiring and do them direct but tried running a new wire from VPX to Flap motor. Still no dice. I then switched the flap control wires opposite from the drawings and it fixed the issue.
My point is it was not a hardware problem though I was sure it was. Since different components are crapping out, it makes it harder to figure out - maybe. From what you are describing it sounds to me like a power spike or shorting.
Good luck with this. I know the frustration and I do not fly IFR. Im sure you will need to be SURE it is figured out before you do that.
