My suggestions:
1. Check all your wiring to ensure that there are no sharp bends or pinches anywhere. A pinch or shard bend could easily be affecting more than one wire.
2. Do you have the circuit breaker values on the VPX set to appropriate levels?
3. How many devices do you have connected to each VPX output? Ideally just one device per output.
4. On the ground, replace the power source feeding the VPX with an adjustable power supply. Then start changing the supply voltage from 13V down to less than 10V and see if the behavior is similar to what you see while flying. You supply voltage could be fluctuating or you battery is going bad.
There are hundreds of VPX devices flying every day. They are quite robust and your experience does not appear to correlate with other peoples experiences with these devices. Your failure mode is not consistent with the way the VPX works so it would seem the problem is likely outside the VPX.
