I used PPG Destothane single stage urethane. All white, very tough paint. Used on lots of airliners.I will be painting Keri Mi this winter. Since there are three different colors of white, I am going to paint her all the same color of white. What brand of paint or type of paint have you all had the best luck with?
Do I need to sand the current paint only or take it all the way down to aluminum? And thanks!I used PPG Destothane single stage urethane. All white, very tough paint. Used on lots of airliners.
Cool! Many thanks!The typical cessna white is ‘Matterhorn white’. When I painted my -7 the painter offered 5 different choices of paint manufacturers with a price spread of 500 between the highest and lowest.
I let them pick what they thought they could give me the best paint job with. They chose jet glo. Single stage.
Its best to do a full strip and paint, but existing paint can be sanded and painted over. There are risks with that, such as poor adhesion, bleed through from contaminates and incompatibility, as well as weight. It all comes down to what you expect at the end, and how much time/money you want to spend.Do I need to sand the current paint only or take it all the way down to aluminum? And th
