All, I have an 8 that the original builder powered with a Mazda Rotary. I quickly realized that this wasn't for me and purchased a IO-360A1B6. However, I have a sweet three-bladed MT electrically actuated prop from the rotary build that seemed to work pretty well. My research shows that it will work on the engine, but i will obviously have to block the governor and plug the hallow crank to use it. The next option is to sell it and pony up much more $$$ for a hydraulic prop. Has anyone ever plugged a crank to run a fixed pitch or electrically actuated prop? If so, what was your experience? Also, where do you acquire the required parts? Direct from Lycoming? Thanks in advance!
