I tap the top port on the servo. Its there to allow tapping for an FP sensor. It is sized for an ORB AN-4 fitting. This runs to my little manifold wherer the FP sensor is and I have another tap there for my return line. Run that to a valve that is rated for fuel exposure and can handle 50 PSI. I put this somewhere in the cabin. Then run a line from the valve back to an AN 4 bulkhead fitting in the tank. You can pull off the round access plate off the tank, intall the fitting and re install the plate.
I’m not building an RV, so I stick to the FFW and avionics threads, but did something similar and wanted to confirm we were on the same sheet of music as I am also a fabricator.
I ran fuel lines from the forward and rearward ports of the high wing tanks, to a tee under the door, to a duplex valve, to the gascolator/sump, to the boost pump, to the shrouded/cooled engine driven pump, to a manifold, to the fuel servo, to a fuel flow sensor on top the engine, to the spider, to the cylinder.
The manifold has fuel pressure, fuel temp, and the very top port has a rivet crushed in it with a .020 hole in it going back to the duplex valve.
I learned this from VAF and think it should work, but not flying yet. My install requires that the fuel system gravity feeds to the pump fast enough to keep it flooded, otherwise it could suck air into the system if my tank unports.
Also, I need to test to make sure that the return fuel with both pumps running is significantly less than measured gravity flow to the pump at worst attitude and min fuel minus engine max consumption. I used 1/2 fuel lines so I think I’ll be okay.
Any thoughts on testing for vapor lock? I have a fuel temp sensor, but I can’t really see the low pressure area at the pump inlet. I could possibly pass the return line through a sight gauge on the wing root and observe for bubbles. Or perhaps I set some limit where mogas is off limits over a certain fuel temp.
Hopefully this isn’t too much thread drift, we are talking about running mogss in an injected kycoming.
