I've been chasing this problem for over a year and have run out of ideas. At low MAP readings I keep losing manifold pressure gauge. It hasn't been critical yet since the SDS box has 2 independent MAP gauges I can reference to stay legal, but it is really annoying. It also came really close to having my wife's commercial check ride cancelled since the DPE saw it X out and tried to say the aircraft was unsafe to fly. It can happen anytime the MAP reading is below 15-16, but it increases in likelihood as it gets down to 10-11, normally during taxi or long descents, but also sometimes during pattern work. It has occasionally read 0 for a few seconds before it shows the X. As soon as throttle is increased it comes back to life.
Troubleshooting so far:
Replaced the sensor twice.
Replaced the line and adapter going to the engine to make sure it wasn't leaking.
Replaced the sensor side harness connector.
Repinned the 3 wires going into the GEA24.
Traced all ground wires during the last annual, didn't find anything loose. All my grounds go to a single point on the firewall, so ground loop issues shouldn't be a factor.
I would appreciate anything else I can check since MAP is one of the more important sensors and it would be nice if it worked consistently.
