I Replaced the open rivet with ports from another project. I think its from Cleveland. Didnt think about skin thickness when I installed it.This is the correct static port. Leave it alone.
I thought the Cleveland port sat fairly flush? (When properly installed and skin thickness was within design parameters)I Replaced the open rivet with ports from another project. I think its from Cleveland. Didnt think about skin thickness when I installed it.
I'm not sure why this becomes so complicated and random for a vital instrument.
Port is .032” proud. Should I blend a ramp around it or does it matter?
It's not what the inside looks like it's the outside. Pics? This is NOT a Cleveland static port. Whose static port is this? Cleveland, Flyboys or a rivet all ok. Why do we complicate this simple and important function?I think mine are about like yours. I did not try to blend them in. This is what mine look like on the inside. Are yours the same? Mine is not flying yet. But, I've been told this is the correct way to install them.
There is a style of static port that frequently gets installed, incorrectly, from the outside. It has caused severe problems with airspeed calibration. My pic was mean to assure the OP that if the inside looks like mine, they are installed correctly IMHO. But, whatever! That's why they call it "Experimental Aviation" after all.It's not what the inside looks like it's the outside. Pics? This is NOT a Cleveland static port. Whose static port is this? Cleveland, Flyboys or a rivet all ok. Why do we complicate this simple and important function?
Thousands out there per plans and no issues. Sometimes simple is better.Still better than vinyl tubing glued to a hollow rivet.
How does “blending” the shape of an incorrectly made part, to try and make it mimic a correctly made part, guarantee that there won’t be any question about the accuracy????I think I’ll blend these in so there won’t be a question about the accuracy. Still better then vinyl tubing glued to a hollow rivet.
Didn't mean to offend, just there a probably several types of static ports that look like this from the inside but are incorrectly made or installed so need to see what is on the outside. I also have seen the Cleveland static with the hole cut to large with the middle ring protruding through which is better as you pointed out mounting the entire port on the outside.There is a style of static port that frequently gets installed, incorrectly, from the outside. It has caused severe problems with airspeed calibration. My pic was mean to assure the OP that if the inside looks like mine, they are installed correctly IMHO. But, whatever! That's why they call it "Experimental Aviation" after all.
Yup, that’s what mine are.I think mine are about like yours. I did not try to blend them in. This is what mine look like on the inside. Are yours the same? Mine is not flying yet. But, I've been told this is the correct way to install them.
I didn’t mean to imply that I think everyone should use the pop rivet and vinyl tubing (even though it does work well and is reliable if actually installed per the instructions….. all of the ones I have ever seen details of the failure weren’t).Wow, this looks like primer wars.
Scott, I understand what you point out about blending it in might not produce accurate results. Scratch that plan. I did some searching for replacements and realized these were probably from a Dynon kit I purchased for a previous project. Problem is their literature doesn’t give a protrusion dimension. I used a similar port on my -8 that was flush but have no idea where it came from.
Yes we call it experimental but making an upgrade from the factory design shouldnt be looked at as some kind of dangerous excursion from the plans. Vans builds light and inexpensive which they certainly did in this case. I’m willing to invest a few bucks to make the improvement.
So, where am I going to find a replacement with the correct protrusion?
Is the Avery port one of the ones that will give accurate readings? https://www.aircraftspruce.com/catalog/avpages/averyefistoolkit.php?clickkey=3199067
What Al ^ said.No. I had them on my 7 and they were 10kts off. Ended up making them flush to the skin and drilling them out for the Vans rivet, which I installed with a little tank sealant and a slight pull on the rivet and then punched out the stem. Accurate after this with the benefit of a nice threaded boss for the fitting to attach the tubing.
Location probably more important than port design. Great article in Kitplanes discusses this.
Great article. I remember reading it when you wrote it.Thanks, that's my article! https://www.kitplanes.com/static-port-location-and-altitude-calibration/
And I agree with [B]bjdecker[/B] post 15, most folks probably have no idea how accurate their static system really is. Regarding the Cleveland ports, they will be accurate if installed the right way - edges flush with the skin on the outside - and in the right place, i.e. where the in flight surface static pressure is neutral, i.e. on the line that marks the transition from higher pressure to lower pressure along the side of the fuselage. Where vertically on that line they are also plays into the accuracy v.s. speed, although not as critical if close to the middle vertically.
The Cleveland ports have an approx. 1/16th step which works conveniently with composite skin, mounting from the inside, but requires some inside shimming for aluminum. The critical factor is location, and for all we know the Van's prescribed locations are in fact optimal, but I've never seen any testing data (has anyone, is it out there?) that confirms it. In the certified world, the effort and testing to determine static port location is elaborate and makes the Van's locations seem a bit cavalier without any data. In the article I described a method by which you can do your own test to zero in on an optimal static port location. The ideal would be to start out with a surface pressure simulation, which might actually be out there for some of the Van's planes.
In any case I would suggest it's a good idea to do some test flights to see how accurate your altitudes and speeds really are. The methods I used are in the article (mostly using outstanding spreadsheets devised by Kevin Horton.)
The Cleveland ports don't require shimming. They have a 025 lip then a further joggle to accept adhesive. Installed as intended the edges are flush with an 025 skin.
You may be thinking of another port.
What is the preferred adhesive to use for the static port to Aluminum skin.
Thought I'd go back through my notes and read up on which static ports I installed and why I installed them that way. Here's an interesting blurb from the instructions that came with my Dynon install kit. I guess I'll have to wait till this bird is flying to see if its accurate like the instructions say:Port is .032” proud. Should I blend a ramp around it or does it matter?
I wouldn't be so quick to show the Avery static port out. I have them on my new 14. Last week a buddy with a very similar 14 and Stein static ports was on my wing. Our indicated speeds matched to the knot. He flys with a local formation group and his indicated speeds match others in the group.No. I had them on my 7 and they were 10kts off. Ended up making them flush to the skin and drilling them out for the Vans rivet, which I installed with a little tank sealant and a slight pull on the rivet and then punched out the stem. Accurate after this with the benefit of a nice threaded boss for the fitting to attach the tubing.
