I agree. I liked the idea of the FTM and potentially getting done with Phase 1 faster, but in the end, it doesn't save much time since if you have a new engine, the first chunk of hours is just getting it broke in enough to feel comfortable doing all the other maneuvers.
For learning the envelope of the airplane it's good, but unless you are testing a brand new design or some major change where you expect flight characteristics to change, it gets pretty boring pretty fast (oh, my numbers for test 4B, once again, exactly match what the other 3k other Van's airplanes have). There are a few tests you need to do even on an established design, like pitot/static calibration etc, but the rest are more like suggestions. Some of the test are actually multiple tests, like the stall tests are actually 12 tests if you do all the combinations. If you don't have a way to change CG loading during flight (water ballast?), by the time you load up, fly out, do test, come back, change load, fly out, test, come back, I bet you could burn off 12 hours just on those tests. In addition, there are some techniques that are better than what the FTM suggests, the one I am thinking of specifically is
using level acceleration to determine climb performance
I also felt it was difficult to fly the airplane, keep a watch out, and try to go through a flight profile for the test by myself. Even with a glass panel recording everything, there's just too much to concentrate on that you lose situational awareness, and a 2nd set of eyes would have been helpful. I understand the APP, but my insurance wouldn't allow anything but solo during Phase 1, negating the benefit of APP.
For me, by the time I felt the engine was broke in enough to start real testing, I was probably not even half way through the official list of tests before I hit 40 hours, and just signed it off as Phase 2 (though the learning and tinkering never stops).
If you sign off your Phase 1 earlier than 40 hours based on the FTM, is there any rule that says the filled out FTM has to stay with/in the airplane?
