Frostbite023
Can someone help diagnose a braking issue I am having? I am hoping this is a relatively easy fix that I can do on my own without taking another trip to the mechanic and spending $500. If you watch the video I took, you will hear the unholy screeching that my right brake is making, it also lacks the same braking power as the left brake. It still brakes, just not as well. I didn't notice any fluid on the ground during pre-flight and the brakes have been fine up to this point. Should I start with bleeding them or is there something else at play here perhaps? I haven't had a chance to check the brake pads but the brakes were checked during the pre-buy and found to be in good shape and that wasn't more than 50 hours ago. And I am not a heavy braker so I can't imagine that the brakes are worn down already (but maybe they are...).
