I am considering a cowl retention system other than the hidden hinge design for attaching the upper cowl to the top of the fuselage. I see many builders choose to use SkyBolts at this location. Can someone explain the advantage of SkyBolts over just using #8 screws into nutplates with the big stainless washers under the screw heads? Is it strictly an appearance issue? I like the hidden hinge system, but getting the pins in and out on a -14 cowl is nearly impossible.
I’ve used a combination of hinges and skybolts on a number of Rv14s and have been very happy w the functionality and aesthetic (less screws or skybolts taking away from the paint scheme).
Hidden hinge pin along the split between the upper and lower cowl. Hinge pin is accessed through the cockpit - see photo below with the pins retracted and circled in blue. I like this verses the option of inserting the horizontal pin from the cooling air inlet area - it’s cleaner looking to me.
Here’s a photo (below) with the cowl removed:
Skybolts on top.
Vertical hinge between cowl and firewall.
Small opening where the horizontal pin comes in from cabin to join the upper and lower cowling (circled in blue as it’s hard to see the opening of the sleeve that the pin comes through)
Overall, I’d still like to find ways to improve ease of access (if only it was as easy as opening the hood on my car) but I find I can remove and replace the cowl solo.
Couple key notes:
* make sure the horizontal pin is lubed or it can be a pain to get it to slide into place.
* I find using skybolts across the top is so much easier than using screws. 1/4 turn and they’re open or closed. No screws to strip or keep track of when you remove them (how did I always lose one or a washer when I used them?).
*when installing the cowl, I put the lower on first. I position it on my harbor freight pneumatic stool (makes it easy to raise the cowl into place) under the engine and then get one of the vertical hinges lined up and drop the pin in just a couple rungs. Then I go and get the other side lined up and secured. Once I get the lower all full secured, I place the upper - adjust the inlets in place, and insert the horizontal pins by reaching in the cockpit (I’m standing in front of the wing making sure the upper and lower cowling hinge is interlocked) and feeding them in.
Sounds more complicated than it is.
Finally, I engage the skybolts.
