Looking for advice from those who have installed a VP-X.
In my installation I've mounted the VP-X box to some angle brackets, screwed to another pair of angle brackets, that are then screwed to the underside of the instrument panel and subpanel. Everything has been primed and it doesn't make for a great low resistance connection to ground.
Should I be concerned about creating a ground loop via the (relatively) high resistance path through the VP-X chassis?
Is it necessary to insulate the VP-X chassis from the airframe, and run a separate wire from chassis to ground bus?
Am I over-thinking this?
I tried emailing Vertical Power/Astronics but haven't received a reply as yet.
