Any epoxy based resin/fiberglass layup should work, but you need to make sure the substrate is in a condition for the bonding. Sand off as much as you can without sacrificing the original shape, use 80 grit for initial epoxy grip. Clean it like you are going into surgery. Any epoxy based solvent should work, but make sure you clean it off completely. I’ve used 91% alcohol from Walgreens to final clean for layup prep and it’s worked well. The fiberglass cloth impregnated with epoxy resin should stick very well to any properly prepared substrate. I’ve used West System epoxy products - available at most local boat supply houses - in most US cities, or from ACS and others. There are many other options for epoxy/glass products. WS is just who I’ve used and had good luck with for the last 27 years.
