As I have mentioned in other threads, the engine in my RV-10 was overhauled and (re)installed a few weeks ago which resulted in a few issues for which this group has been extremely helpful.
Ever since the plane started flying again after the engine install (last 4 weeks or so), I had noticed that once I turned the masters on but before the starting the engine, the RPM indicator would show random non-zero values. Once the engine was started, the RPM indications seemed fine.
On a flight last weekend, I started to see wonky RPM indications after the engine was started (see attached image - RPM is in green in the chart at the bottom). When the engine was at what I thought was around 1000 RPM, it was showing 1300-1400. Idle was showing about 1000-1100 (it normally idles at 750), run-up was showing 2300 (vs. 1800-1850) and even on takeoff it was showing above 2700 (vs. a normal indication of 2670). It was obvious that it was an indication issue since the prop sounded fine and wasn't surging and also, things seem to settle down a couple of min after takeoff so I chose to continue the flight.
I had dual PMags installed about a year ago and was closely involved in the wiring and configuration. The RPM indication comes from one of the PMags and I suspect that may be providing a bad indication.
I wanted to get some ideas from the group on what I should be looking for (or steps I should take) as I troubleshoot this issue. Could it also be a failure on the Pmag? I guess one easy thing to do would be to get the RPM indication from the other PMag. Any other ideas would be much appreciated.
Thanks.
Thanks.
