I'm curious if anyone here has a Mini-X installed next to either a Dynon or Garmin primary EFIS system? My Mini-X heading is often 20°, sometimes 50° off from my Dynon setup; the Dynon setup makes sense (east is actually east, for example), and the winds aloft vector computed by the Dynon setup also makes sense. I have dual ADAHRS for the Dynon, both an SV-ADAHRS-200 and -201. I primarily leave both screens on the 200, at some point I should check the 201 but I suspect its of little consequence here.
1) I performed a magnetometer calibration on my Mini-X back in the spring, this then basically disabled the magnetometer (for some odd reason).
2) GRT were great and RMA'd my magnetometer for a low cost.
3) I reinstalled said magnetometer, and have done several calibrations while following their instructions, at different locations. The latest calibration was completed on a compass rose at a nearby airfield; little change from my local field.
What is odd is the offset; you start calibrating the Mini-X mag while tracking north. Hence, while flying north, both the Dynon and Mini-X are within 1° of each other. During the first hour of flight, at headings other than due north, I've seen up to 50° off on the Mini-X (particularly bad east or west bound). Any thoughts?
