Vans SB00080/Airflow Services SB0001
JHartline
I think most of us have the 2006X (Vans P/N EA-00002) oil cooler as standard equipment. I tried calling Airflow Services to ask when the suspect coolers were manufactured or how many reports of problems they had gotten. Call goes to VM, so no luck there. They did just put out revision A (thank goodness) which notes that the suspect coolers were manufactured in 2019. It came out right after I used my borescope camera to read my SN.
Proper action is to check of course, but it really helps to know the timeframe.
Hi folks,
I have written to Airflow Services regarding their SB on the 2006X oil coolers. Sadly there has been no reply. Their web page regarding the SB does not open for me. Did anyone on the forum download the page with the affected serial numbers when it was available? If so, could I kindly request a copy by DM.
If it helps my serial number is A22-14057-16. I wonder if the -16 relates to 2016? The affected batch was in production 2019. My kit was packed in 2022.
Many thanks in advance,
Richard
Hi folks,
Richard
trying to bring this back to the top. I too need to find the list of serial numbers affected. Can't find the sb-0001 from airflow anywhere. Anyone have the list?
Hi Mike,
I should have closed the loop on this earlier, but I did eventually find the SB. The bold highlighting is mine.
Richard
35282 Vista de Todo, Capistrano Beach, CA 92624
www.airflow-system.com • (949) 218-9701
Oil Cooler Service Bulletin 0001 – REV N/C
Date Released: June 12, 2023
Date Effective: June 12, 2023
Affected Models: Subject Scope of the Issue: Required Action: 2006X X-Series Oil Coolers, serial numbers K19-16202-25 through 40.
Potential oil leak from the vanes and/or core area of the oil cooler due to potential
manufacturing defect.
The service bulletin only applies to 2006X X-Series Oil Coolers serial numbers K19-16202-25
through 40. We are still collecting data, if your oil cooler is outside the affected range, we are
interested in knowing about any failures.
Inspect your 2006X oil cooler data plate and determine if your oil cooler falls within this serial
number range. If it does, do not continue to fly your aircraft. Send Airflow Systems an email at
[email protected] with your contact information and we will send you a replacement
oil cooler and return shipping instructions for your oil cooler. DO NOT THROW AWAY YOUR OLD
COOLER, WE REQUIRE THEM FOR EXCHANGE AND INSPECTION.
Before further flight.
Time of Compliance: Supersedes Notice: N/A
Page 1 of 1
© Airflow Systems 2023
