Also, has anyone had issues with the access panels oil canning? I've seen two RVs with similar access panels that were oil canned in or out...one on a -7 and the other a -14, and don't know if they were made with Van's kit or not, but they looked a bit unsightly.
I wish the entire upper forward fuselage skin was attached with screws.
Mark,Has anyone with an RV-14 actually tried replacing the struts through these access panels? Seems like a job that requires at least two hands, and since the struts are off to the sides I'm wondering if you can get both arms in there far enough to reach them without having someone else lying on the floor under the panel to help...?
For the above reasons, I've been mulling putting larger access panels in the curved sides of the skin instead of the flat center section. It's more work to roll your own and get the access cover curved to fit properly, but it won't oil can and seems easier to stand next to the airplane & reach inside to work on things. Others have done this, like this example from Marvin McGraw's -14.
For me it wasn’t. (Someone had to cast the dissenting vote) I designed my own panel layout and also, where the boxes would all go. It took a while to position everything but I’m quite happy with it. There is nothing in the “bat cave” except my forest of ground tabs. When I did those I temporarily mounted the ground block aft of the sub panel. Ran all my ground wires nice and neat to the block and then, through the glove box opening, bolted it to the firewall. Quite easy, relatively speaking.Is it worth the labor?
So did I. IMVHO almost a necessity on a slider.I installed four of those access panels on my -7. Very handy. No oil canning. I agree with mburch, helps to pre-form the flanges and the covers a bit. Use the skin and clecos in every hole.
Any opinions about the value of this kit for easing access to the back of the panel? My panel is coming from Stein with two G3X's etc. I'm assuming there will be a lot of remote boxes and accessories to mount. All in put welcome. Is it worth the labor?
Appreciate this comment, usually people back their original choice.Installed it in my 14 and never used.
Waist of time IMHO
Mark,I think I can do without the access panels from an avionics perspective (by mounting the equipment in a more accessible location), but if--or when--I have to replace the canopy struts, it seems like that job would be a real pain to do entirely from underneath the panel. Strategy: forgo installing the access panels and sell the airplane before it needs new struts![]()
After two yeas of use, one of my canopy struts went tits up. With the access panels installed I decided to replace the strut from behind the panel. That way, I wouldn’t have to go through the hassle of unscrewing the panel and re-sealing it after the job.I think I can do without the access panels from an avionics perspective (by mounting the equipment in a more accessible location), but if--or when--I have to replace the canopy struts, it seems like that job would be a real pain to do entirely from underneath the panel. Strategy: forgo installing the access panels and sell the airplane before it needs new struts![]()
