Rain damage to paint on prop blades
georgemohr
Does this look like a reasonable amount of paint damage for a 100h Hartzel CS prop after one flight in rain (and not really hard rain)... Both sides are similar, both blades as well. Thoughts?
Wow, I have flown in the rain and a few times in a really hard rain and never such thing happened. I can't tell if the visible gray is aluminum or the gray paint that is in the front portion of the plane but if aluminum it will need to be addressed for corrosion protection.
Was my partner's flight so I'll have to ask, but I'll guess 160 ktas for 1/2 hour of rain based on his description.
In recent times there have been some paint issues, and it may be paint spec or system. Our prop (now 2400hrs) was overhauled and repainted. It has done as your prop has. Obviously not factory new, but I wonder if something in the paint system has changed?
Who knows.
Is that 100 TTSN or 100 SMOH? If SMOH, who did the overhaul?
I experienced paint peeling off in sheets on a MT one flight through light rain after an overhaul by a shop in GA.
Airspeed is one factor, but RPM makes a big difference. So does the type of paint, and if sand has eroded the LE of the blade already then it is even more susceptible to damage. At 2700 rpm the tip of a 74" prop is going 870ft/sec or about 600 mph w/o airspeed vector. A Diamond pilot friend said he drops rpm to 2200 for rain.
I assumed as much. Rain ablation on a wing leading edge might be airspeed, but those prop blades are moving much too fast for a few knots of forward speed to matter.
I'll document and open a ticket with Hartzell. Thanks all.
-G
I experienced the same, from the same shop, twice. Never again.
In discussions with Peter M. of MT in Deland, he advised dialing the RPM back to something below 2300 when in rain. This was several years ago.
In more recent discussions with John. N. of McFarlane, he said they can hit the leading edges of MT props now with a pressure washer from close range with no adverse affects. due to improved paint technology. I've never tried that but I haven't had any issues since I had my MT overhauled in Deland.
I would be calling Hartzell if I was the OP.
Interesting, I also have not had any trouble since my last MT overhaul in Deland.
Some updates. Hartzell told us we are out of warranty (16 months) so no joy on that front. They also suggested this was "normal" erosion, even though I pointed out that 95% of this damage happened on one fight. They also implied that we washed the blades with an incompatible soap (didn't) and that we fly off of bad tarmac (don't).
Not a great outcome...
I guess we will have to pull the prop at annual this winter and have it refinished.
That's a rather disappointing response to say the least.
To put it in perspective, my long out of warranty (years) Laversab 6300 P-S test box (which cost more than a new prop) was having an issue so I sent it to them fully expecting a large repair bill, they did a full upgrade to the latest version, new pump and recalibration.... for ZERO dollars!
They also paid for shipping both ways, now that's what I call customer service!!!!!!!!
This is what prop damage from normal wear and tear actually looks like. https://www.kitplanes.com/maintenance-matters-22/
Also note in that kitplanes article, it recommends SANDING the paint off because when it's been painted correctly, that's what it takes to remove.
The picture posted looks like the paint was defective and failed to adhere to the blade. Paint only comes off in big flakes like that when there is a bonding issue.
Companies aren't supposed to be able to give a customer a factory defective product and then say it's out of warranty when they find the defect. I had the same paint peeling issue on a new prop that I purchased from a major company. They initially said they wouldn't pay for anything and denied it was a problem. I informed them that they owed me a defect free prop based on the warrant of implied merchantability, and they eventually admitted it was their problem to take care of.
George,
Hartzell defines "normal" erosion in its HARTZELL PROPELLER OWNER'S MANUAL 115N as."Normal erosion (sand-blasted appearance) on the leading edge of the blade is permitted and does not require removal before further flight."
Inspection and Check - Page 5-3 - 1,B,(1), (a)
What you are seeing is paint adhesion failure.
Hartzell is blowing smoke at you; hoping that you'll go away. Hartzell is now under private equity firm ownership.
Since exposed aluminum on propeller blades invites corrosion, it is a safety concern. Please consider submitting a Form FAA 8010-4 - Malfunction or Defect Report https://www.faa.gov/documentLibrary/media/Form/FAA_Form_8010-4_.pdf
George,
Post #21 and this^: I would be tempted to let Hartzell know that the law is on your side (#21) and that you are filing a 8010-4 with the FAA. That might put a fire under their resistant butts.........
Had the same problem on my Hartzell BA. Paint non-adherence after about 150 hrs since new. They paid for the repaint but I had to remove and replace it myself. Seems to be a fairly common problem with them
Keep those FAA 8010-4 - Malfunction or Defect Reports coming. This problem might then be addressed proactively by Hartzell to avoid dealing with an Airworthiness Directive.
Props can be refinished on the aircraft. See Taking Care of Your Metal Prop I touch up my prop every two years or so.
That sucks that Hartzell will not offer a re-paint, or at least a discount if flown to their shop in Piqua for touch-up on that. To me it does look to be some adhesion problem by the picture. You do not show your location. I recommend that when the repair is done that the proper Sherwin Williams "Polane" paint is used. If prepped correctly will last for years and years. Any good propeller shop should/will be able to supply the repaint service. We call it a "Perfume" at the prop shop where I work. Minor abrasion is removed, cleaned, alodine bare aluminum, scuff of existing paint and re-coat of the factory Polane paints. We add grease per 115N, and static balance is also performed while we have it. That is the proper way to address this issue IMO. Once back on the plane, fly it a few hours, top off with grease per 115N and then a dynamic balance will make it as smooth as can be.
There is some good general prop advice in this AC (Most pics taken at our shop many years ago):
Oh for Christ's sake Hartzell, how much would it cost for a little bit of paint to make it right after what is clearly not normal erosion. Pisses me right off when companies have this terrible of support! At least when it comes to props we have options.
Just a guess, but suspect the "old hartzell" is long gone. They were bought by a private equity firm and this type of behavior is pretty common, as the goals change purely to short term profitibility. If they are successfull in buying most of the competitors as well (already own WW), This behavior is no longer a reason not to buy, as all the options will be the same.
My MT looks like the original photo after a slow ride in the rain. MT has leading edge SS sheath. SS is notorious hard to have paint adhere. MT told me that they changed their paint in 2019 to get better results. Mine is a 2019 so didn’t work for me. At OSH , MT offered some touch up paint …… I’m still waiting on it …
