outnumbered
For the horizontal hinges connecting the upper and lower cowl
1) are the standard rolled hinges sufficient or should I go with extruded ?
2) do folks go with offset hinges (pics would help) so the the eyelets are not seen at the seam ?
Would appreciate hinge part numbers if folks didn’t use the stock vans hinge.
