You received a 120 Volt AC adapter to a lower voltage I am sure......Plugging a Mini into 120 volts your Mini will not be happyHow are you powering the mini? Mine came with just a 120 outlet power adaptor.
i used to be able to do that and really miss it. A couple of years ago, apple changed something and now the phone doesn’t even try to connect with a network once over 2000’.Yep, I am guilty of considering sending a quick text while cruising at over 8k feet to let somebody know my ETA or about a diversion.
Larry,i used to be able to do that and really miss it. A couple of years ago, apple changed something and now the phone doesn’t even try to connect with a network once over 2000’.
Any tips for how to get that functionality back?
I have an SE 2nd gen. Not big on upgrades, so don't know where that sits in their timeline. is this messaging built in or is it an app?Larry,
Have you tried satellite messaging on your iPhone? If you have a iPhone 14 or newer, you're able to send and receive messages via Globalstar satellites. It's not perfect, but it does work.
HTH
Dave
Trying to do this math - are we talking current draw at 12V? Because 40W at 12V is going to mean 3.3A, correct?Just FYI the Mini draws less than 1/2 amp (40 watts on average) so voltage drop is fairly low. Does need a minimum of 12 volts.
The satellite messaging is built in, but only on the newest devices (I think 14 and newer)I have an SE 2nd gen. Not big on upgrades, so don't know where that sits in their timeline. is this messaging built in or is it an app?
No app required, you can select satellite messaging via the control panel when the signal strength indicator shows “SOS” and a satellite icon. Once you’ve gone through the connection process, you use iMessage as you normally would.Is this messaging built in or is it an app?
Exactly. The 120 volt wall adaptor drops it down to 30 volts 2 amps and it is happy. In our RV (Recreational Vehicle), boondocking (not plugged in) the 12volt adaptor we have for the mini will not reliably run it. But if we put a small inverter on it and run the 120 volt adaptor everything's fine. I've read some use a step up transformer to go from 12 to 24 and that cures the problem. I was hoping to hear how those using it in our airplane RV's are powering it reliably.Trying to do this math - are we talking current draw at 12V? Because 40W at 12V is going to mean 3.3A, correct?
Correct, mine draws 3-4 amps on average, very reliable. Maybe because my main bus runs at 14.2 volts in flight while using. Also use 12 awg wiring to cigarette plug that is 9 ft. Not much voltage drop.Trying to do this math - are we talking current draw at 12V? Because 40W at 12V is going to mean 3.3A, correct?
