I went with Grand Rapids 10.1 Horizon. G5 Garmin Backup EFIS, GPS175, ICOM IC220A, Trig TT22 Transponder (remote/ADS-B out) .
The ADS-B IN is a Stratux ADS-B Dual Band Receiver Aviation Weather and Traffic I built which is both WiFi and wired to the GRT EFIS.
Optional I panel mounted the GRT EIS 4000 (Engine Indication). It is optional because it is echoed on the EFIS.
If my EFIS goes out I have engine gauges, including MAP/RPM.
The ICOM IC-A220, Dualwatch and priority watch functions, tons of features, panel mounted and remoted tuned by the GRT EFIS. The EFIS data base can "push" a Freq into standby. The ICOM has serial port. If for some reason EFIS went out, I still have COM. That is the NICE thing about GRT it is playing NICE with ICOM and TRIG and STRATUX and even Garmin GPS, with approach info.
If EFIS goes out the Trig TT22 remote transponder will still work, just can't control it. It will stay on last squawk. I could put a control head (2.25" control head and a switch), but decided not to.
The Garmin G5 has infernal battery as back up. The GRT Horizon 10.1 EFIS has backup battery as well, but plane will be flown IFR. I did not go with the awesome GRT Mini as backup, which is a full meal deal EFIS (with map, engine gauges) because it was a tad too big. The G5 is smaller and like the idea of having a totally independent system (and brand) for keeping the plane upright in the clouds.
(Note: I was not going to go with Garmin of any kind but found a used G5, GMU11 (remote magnetometer), GAD29 (ARINC429 interface), Backup battery, all the connectors (used with cut harness, but pins are cheap) used from Wentworth (out of an RV-6A that did s slow landing accident and parted out. Used can save money. Garmin will get you with all the extras. GRT includes most things, including wiring, but there are still ala carte items. Again Garmin, Dynon are great.)
To round it out the Garmin GPS175 is a
TSO-C146, LPV approach, IFR Navigator. I was going to leave the IFR GPS out for upgrade in future, but it would be a pain to retro fit and wire. I got a screaming deal on sale from Gulf Coast, I recall a little over $5,000 with tray and antenna.
All in all I have about $13,000 into my IFR panel in 2021-2022 dollars. Oh yes, I have had Mil Spec switches and CB's for a long time, buying them a long time ago. If I had to buy those outright today it would cost a good chunk.. The ICOM A220 was used as well as the G5 as I mention. The GRT Horizon 10.1 EFIS drives two A/P servos for Roll and Pitch, has V/S mode, Alt capture, and of course couples to GPS navigator. The price includes the servos. So about $15k for an IFR panel using GRT, ICOM (used), TRIG, GARMIN (used).
The DRE Intercom is an auto panel, not really but it is stereo and has aux inputs, so it collects all the audio and an awesome intercom with a lot of isolation and selections (it will expand to 4 place, but it is nice passenger can listen to music while you do ATC only if you want. If you have music on it will of course cut the music out as most intercoms do.) The ICOM A220 has a VOX intercom built in. I did not use it. I could have saved money not going with the DRE, but like many things, I bought the DRE (no longer in business) on sale at Oshkosh thinking I will use it in future. Might as well use it. It came as part of the special full harness, jacks. Very nice quality. You need an intercom and many devices have it integrated is the point. Do you need stereo music? No and many headsets can pipe in music if you like with Bluetooth.
GRT is more friendly, not as proprietary. Free updates. I mostly did it because I have had GRT before. You can't go wrong with Dynon or Garmin, but they are more money. In the end is a big difference? Up to you. I do know I went through 5 stages of grief buying $5/ft CANBUS wire to connect the G5 to the Magnetometer and GAD429 (interface for GPS serial to CANBUS). Garmin does not tell you about all those other boxes, $400 there, $400 her, a couple of $100 for wire. I joke it is all relevant.
Decide your budget. If you are a PURE VFR Day/Night guy you can get a very simple functional panel for under $10k. Or you can go with a $40k turn redundant IFR Garmin Panel, and have a Pro panel builder service buy, fabricate, wire. finish, label, set up. I enjoyed learning to wire a "glass panel". My first RV was 100% steam driven with a portable GPS hanging off a mount. It was IFR with King KI155 VOR/LOC/GS but still very traditional circa late 80's.
Pic below is my panel "mockup" right after I got panel cut. The big hole to right is whatever I want: cover plate, service access, big beautiful open storage box, up to 4 x 2.25" instruments (example I have instrumements in my spare draw like DAVTRON clock and cool military G-meter for decades). I can play, than redo the cover panel without tearing up the panel. Picture right after getting panel laser cut locally. I used black sheet of 0.080 and had it cut and flange bent, not the stock 0.063 panel. I still have to paint, prime and label. I will set this up on bench and wire it as much as I can out of plane.
The draft is from Panel Designer from Hanger Flying. THANK YOU Hanger Flying... It is not CAD but close to scale. I used free CAD program LibreCAD to create DXF file to cut panel out. I went to FedEx Print and printed it out full size. I glued it to a plexi glass and cut it out by hand. It was helpful before cutting expensive metal. A local plexi fab shop had scrap I got free. Yeah. I did catch an issue with EIS hitting the structure for a slider at top. It was minor and made a spacer for the EIS on 3D printer to give the bezel thickness like the other instruments and add clearance behind. Also switches were moved around. NOT all items are drilled and mounted yet. I just did the priority items first and will add in light dimmer, elt control, A/P disconnect button....
You can spend as little or as much as you like on the panel. I could have saved $6k by not getting an IFR GPS... so yes a "deluxe" VFR panel with A/P can be done well under $10k with GRT at least. For NAV an IPAD or many of the other tablet like Aviation GPS can be used. if you shop around and DO ALL THE WORK yourself you can save $10k or more. I did pay $200 to have panel laser cut. It was worth it, but a luxury.
