A quick search didn't turn up easy hits on my query. Apologies if this has been covered 514 times before.
Lucky me. Just got my first flat. Thankfully it happened slowly overnight and not on landing.
I was just talking to the shop that can swap the tire out for me (not something I want to mess with right this minute, given a few other things going on) and the shop guys asked if the tie down rings are a single point jack point. When I built the plane, I supported the entire cabin with a forklift when attaching the landing gear, so I never had to jack one side. I thought that maybe you could get something on the underside of the brake housing, but the shop thinks that is a little tight.
Can they jack the side up on the ring? If not, where do people recommend jacking up a single side for tire / tube / wheel replacement?
Thanks in advance for the help!
