RV8Squaz
Hello.
The rudder cables ride inside a piece of nylon tubing where they exit the fuselage near the tail of the RV-8. I'm sure it's similar in other models. The tubing is held in place with an adel clamp affixed to the the side skin on the inside. In any case, over 2000 hours and 18 years of use, the rudder cables have worn right through the tubing and started wearing into the aluminum side skin. Fortunately, the cables are tougher than the aluminum and didn't damage the cables. However, the aluminum is worn a bit. I'll dress it up a bit with a round file and scothbrite to prevent it from cracking . I caught it early thank goodness.
Any guesses what type of tubing Vans might have used? There's Poly-Flow, Nylo-Seal, and Nylaflow. I'm guessing it's Nylaflow based on the description in the ACS catalog. I'll probably call Vans tomorrow.
Jerry
Jerry
