I have been posting on this thread https://vansairforce.net/threads/garmin-g3x-video-in.116145/#post-1863005
The Garmin G3X has a BNC connector that will accept Astm region 1 standards for video in. Apparently the world has moved on from the Astm region 1 standard (At least for thermal cameras) and those cameras are no longer available.
It was pointed out that thermal cameras with ethernet output are available and there are devices that can convert the signal to an analog signal compatible with Astm region 1 standards.
Thermal cameras have evolved into highly technical devices that are used to accurately measure heat in the manufacturing process.
I’m looking for some help identifying a suitable thermal camera that can display a thermal image on my G3X similar to the astronics unit https://www.astronics.com/dual-sensor-evs without spending 11k.
I know there are lots of thermal cameras out there. Looking at all the choices and the specs, I’m baffled as to which one I should gamble on. I know I want something that looks something like either a box or a cigar that is sealed up, so I can mount it on my aircraft.
I’m pretty sure that there are some folks here that understand this far better than I ever could. I would appreciate any guidance.
