Rudder Trim
g zero
Came up with a simple in flight adjustable rudder trim . Used a SS turnbuckle and some AN hardware attached to the passenger rudder pedal.
Easy to dial in the ball and quickly removable.
No Springs?
So you have to disconnect this before you can move the rudder? That would make it more like a control lock than trim. Not a great idea in flight. What am I missing?
Trim
It’s for cross country auto pilot trips …4 hour legs at 10,000ft ……
Similar concept, incorporating a bungee. Other end hooks into a hole in the rear seat mushroom. On for cruise, off for everything else.
Interesting. I may borrow this idea. While testing, I found that I need a smidgen of right rudder to keep it coordinated.
I tried the Para Cord first with a plastic clip that fit into the gear tower … couldn’t “Dial it in “ for my OCD Needs 😂.
So things don't sometimes happen during those 4 hours at 10K that might require immediate emergency use of the rudder? Wake turbulence? Mountain wave? Not sure how a locked control system at any time is acceptable. (Maybe I'm not understanding how it works?)
Take a look at the pic …. The turnbuckle sits on an 3 bolt / pin …. Any Knuckle Head with a GED could remove it quickly 😂
Forget the rudder trim, I want to know more about the 'Ejection' switch. You have live ejection seats in that thing? :)
Trim
Right rudder pedal spring slightly heavier than left. Attached to a homemade vernier control. Concept dates to a Sport Aviation magazine from the 60's??
Works perfect, no locked controls
That's so foolproof that I'm sure all the major manufacturers will now adopt it. :rolleyes:
Seems like a surprisingly bad idea to me, but hey...you do you.
Can you post a link to the thread where you shared this with us before? I thought it was a very thoughtful mod and had it on my list of things to work on "one of these days." I cannot find it searching.
Avoid tying bungees to your rudder pedals along with manual controlled trim tabs or permanent wedges and just install a yaw damper. Reacts to gusts, thermals, and other external forces (lazy feet) immediately. Pics with and w/o yaw damper on. and off. I really like mine (And so does my passenger)
Copied this idea from another builder. I personally would never lock a control axis while in flight.
Fully adjustable, has no noticeable effect on ground handling or if you forget to adjust it after an extended climb or something. This could easily be 3D printed if someone wanted to take the time.
Hi, do you somewhere have the files for this one. Would love to copy it too.
Kind regards
Ha! Ejection switch.
I had an extra unused breaker in my first 7. I labeled it PAX EJECT. Not every passenger got the humorous intent😵‍💫
Kind regards
The plan was in my head, but I updated that link post with a basic drawing with all the dimensions you'll need to get started. Included here as well.
