So you have to disconnect this before you can move the rudder? That would make it more like a control lock than trim. Not a great idea in flight. What am I missing?
Similar concept, incorporating a bungee. Other end hooks into a hole in the rear seat mushroom. On for cruise, off for everything else.
It’s for cross country auto pilot trips …4 hour legs at 10,000ft ……
So things don't sometimes happen during those 4 hours at 10K that might require immediate emergency use of the rudder? Wake turbulence? Mountain wave? Not sure how a locked control system at any time is acceptable. (Maybe I'm not understanding how it works?)
Came up with a simple in flight adjustable rudder trim . Used a SS turnbuckle and some AN hardware attached to the passenger rudder pedal.
Easy to dial in the ball and quickly removable.
Take a look at the pic …. The turnbuckle sits on an 3 bolt / pin …. Any Knuckle Head with a GED could remove it quickly![]()
Right rudder pedal spring slightly heavier than left. Attached to a homemade vernier control. Concept dates to a Sport Aviation magazine from the 60's??
Works perfect, no locked controls
Hi, do you somewhere have the files for this one. Would love to copy it too.Copied this idea from another builder. I personally would never lock a control axis while in flight.
Fully adjustable, has no noticeable effect on ground handling or if you forget to adjust it after an extended climb or something. This could easily be 3D printed if someone wanted to take the time.
RV8 Rudder Trim
My 8 needed a tab on the rudder, as it requires a touch of right rudder in level cruise. I was considering various options when I came across this excellent idea in Danny King's RV8 at Oshkosh a few weeks ago. I did some googling and couldn't find anything else like this, so I figured I'd post...vansairforce.net
The plan was in my head, but I updated that link post with a basic drawing with all the dimensions you'll need to get started. Included here as well.Hi, do you somewhere have the files for this one. Would love to copy it too.
Kind regards
