i'm just observing the thread, but the scale seem to be leaning in favor of @RV-9erA due to this:
4. Avoid rapid acceleration after a cold start. Do not exceed idle RPM, recommended in the engine
Operator’s Manual, until oil pressure is stabilized above the minimum idling range. Allow up to one
minute for oil pressure to stabilize, since lines to the gage may remain cold. If oil pressure is not
indicated within 30 seconds, shut down the engine and determine the cause. If no leaks or damage is
found, repeat the pre- heat before restarting.
5. Allow the engine to warm up at idle speed until oil pressure and temperature are stabilized within
normal limits and proceed to ground check in accordance with the airframe manufacturer’s Pilots
Operating Handbook
OTOH:
www.lycoming.com
After start, do not idle engine below 1000 RPM. It’s not good practice to idle engines below 1000 RPM at any time. This is particularly true during cold weather to prevent lead fouling of spark plugs. (Exception – Piper Pressurized Navajo)
Operating Handbook
OTOH:
Operating in Cold Weather
A note that came in the mail from a Flyer reader included a suggestion that went something like this, “How about an article dealing more extensively with the cold-start problem?” This suggestion was a good one as it provided an opportunity to share information about a variety of cold-weather...
