I’m nearing the end of my RV-12iS build. Garmin VFR dual screen, autopilot with GMC 507 panel controller. When I completed the electrical and avionics installation months ago and first powered it up, the pitch trim initially worked normally on both sticks, but after cycling it several times it stopped functioning. In addition, none of the buttons or controls on the GMC 507 function, although the unit lights up when the master is turned on and the backlights on the controls remain on. The trim motor works normally in both directions when a 9V battery is connected to the appropriate pins on the db9 connector that plugs into the back of the AV-60000 power module. Fuses are all ok (and tried new replacements as well). There are no loose or bent pins in the connectors, and I confirmed that the builder-installed pins in the db9 connector are wired correctly. The G3x recognizes that the autopilot is present on the configuration screens, but none of the controls function on the GMC 507. The trim and AP issues are likely related, since the trim is run through the autopilot.
I’ve worked with Van’s builder support for months to troubleshoot this. The last thing they suggested was that the AV-60000 might be bad; they requested that I remove it and send it back to Van’s for testing. I found out today that it tested normally, and is being sent back to me. Meanwhile, the Van’s builder support tech I was working with has retired, so I’m now back to square one. And did I say I’m frustrated?
If anyone has thoughts, suggestions, or further troubleshooting ideas, they would be much appreciated. My situation is complicated by the fact that the airplane is 4 hours away, so I’m not able to run out and try quick fixes. Thanks to all!
