It would be helpful if you could post pictures of how your door jambs look. That might help determine your easiest path forward.Purchased an Rv-10 with no door seals. Looking for suggestions for a replacement.
Bill
Agreed lots of ways to finish off the door jamb area. Pics would help. BTW since I did not want to install the seals before paint left them off and noise level not too bad but obviously rain might be an issue.It would be helpful if you could post pictures of how your door jambs look. That might help determine your easiest path forward.
Test it with a 3”x5” card. Put the card in the door frame, shut the door, feel how much resistance there is when pulling the card out. The more the better.Well shows my short observation. I do have a door seal(14 yrs. Old). I just question how affective it is because it is really loud in the cockpit. Any suggestions?
I assume you have seen how "most" 10's built now use a McMaster-Carr seal on the "joggle" around the door frame. The added noises is probably normal for a 10 and the best way to reduce noise is a good pair of ANR headsets. I do not have a door seal installed yet (waiting for painting to install) and it's about the same noise level as my 14 measured with a soundcheck app.Well shows my short observation. I do have a door seal(14 yrs. Old). I just question how affective it is because it is really loud in the cockpit. Any suggestions?
The stock solution does use pop rivets and the poster's seals appear to be stock (or very similar). What he needs to determine is if the fitment is good and if the seals still have enough flexibility/spring to do an adequate job.Th
My recollection of stock is that it is a stick on application, not a rivet in place solution as shown in the photos.
2 suggestions.Well shows my short observation. I do have a door seal(14 yrs. Old). I just question how affective it is because it is really loud in the cockpit. Any suggestions?
Regarding the second comment... The planearound center latch is (IMO) the very best way to protect yourself and your airplane against losing a door. I strongly recommend it (and am not affiliated with the company other than as a satisfied customer). For what it is worth, I'm aware of one fatality that was door related (the one in California). I'm also aware of multiple door losses, at least one of which resulted in substantial aircraft damage because the departing door hit the horizontal stabilizer.2. This one is much more important. If you haven’t already- read SB 10-1-4. I’m surprised there are still non compliant 10s flying around. Not trying to have a go. But it’s been a factor in multiple fatalities so just drawing your attention to it in case you weren’t aware. Id strongly recommend the planearound center latch instead of the vans 3rd latch.
Enjoy your RV10! They are wonderful aircraft
planearound.com
2 suggestions.
1. Register with Vans and get a set of plans and see how the seals are supposed to be done stock. Don’t worry about retrofitting the McMaster mod on a flying airplane you didn’t build. Yours appear to be non continuous. As designed it’s supposed to be one continuous piece of seal
I think you're right on both counts. I remember the cleco's to hold it in place and thought I remembered pop rivets (in addition to sealant) as a belt and suspenders approach. The seal in the picture looks a bit like the one from Van's, but on further inspection isn't the Van's seal.Can you point out to me where in the plans this is called for? I'm not seeing that. Also, the picture does not seem to be rubber as what I am reading.
Short answer. No.The builder installed deeper reinforced brackets for the door pins along with an alerting system to make sure all pins are engaged. I would think that is sufficient?!?
While I agree that the center latch is the best approach in this regard, there are other options, just not as foolproof as the center latch. The big problem is the strut pushes the rear of the door away, so easy to have the rear pin not hit its socket. This is compounded by the fact you can’t easily see it and from the front, it appears to be fully shut. An insidious problem.Short answer. No.
Longer answer. I think a dozen or so RV-10's have lost a door. Might be 8, might be 15. As far as I know, none of them had the planearound center latch. What it does is pull the door(s) tight as you cycle the handle so your door pins land in the holes in the cabin top. Just as good, you can see that both planearound latches are properly seated. What seems to happen is people close the doors and don't get the aft pin seated, then the door pops open in flight. Unfortunately, the magnetic switches that are part of the standard latch warning kit are fairly sensitive and can give a false "closed" reading. Alternately, pilots miss the "door pins not engaged" light, or the light is broken, or they didn't install it, or... So the indicator lights are imperfect. In every "Highly recommended mod's for the RV-10" thread, the Planearound latch is at the top of the list.
