Just bought an RV-8 and had the carb heat cable (CT A-740) break at the flapper door connecting arm. My question is, do I need to replace the entire cable or can I replace the inner wire (use the knob and wire from a new unit)? Looking at the placement of the existing control placement there is very limited to no access for replacement of the entire unit. Thanks in advance for your help.
