4nneK
I'm New Here
I just replaced the old lead-acid battery in my legacy 12 with an EarthX. In the past, I would occasionally connect a trickle charger to make sure the battery was topped off. Especially when playing with the avionics on the ground.
I know the new lithium battery isn't compatible with the cheap old trickle charger that I was using, so I'm looking for a replacement. What are you all using to keep your lithium batteries charged?
It looks like EarthX sells a trickle charger, but it is a little more expensive than my uninformed brain expected.
Also, is it normal to see amps bouncing between 0 and 1 during the flight duration? I truly can't remember if the plane has always had these low amps (still in the green arc though.)
