I am having a go at planning out my potential panel (mostly at this stage to make sure i can fit all the switches i need etc).
I had planned for all my engine (SDS) switches on the left hand panel, below the G5 - but it is very tight!
Any opinions or real world experience on the minimum distance below the G5 which switches are usable? I don't have the G5 at this stage to do a mock-up.
Below are some images from my first go at working with OnShape. If anyone wants to view the actual 3D file, i think you should be able to access it here.
The PFD is as far to the right as it can go. The G5 is as high as it can go (approx 12-13mm inside of the panel edges). The switches are as close to the bottom lower frame as i can get (assiming i move the heater control somewhere else). This leaves the switches around 14mm below (1/2" ish) and 5mm further out than the G5.
These switches would be the engine and generator masters at the top - so only used once per flight.
