This is what I use. Its good on several of the homebuilder axles.
https://store.vansaircraft.com/vans-axle-wrench-kit-for-1-1-2-aluminum-nuts-tool-axle-wrench.html
Maybe I missing something, from the Beringer manual:
Torque axle nut to contact by hands, do not force. (WARNING)
The Beringer does use roller bearings, but I don't recall them having a center spacer to avoid side loading them like the nose wheel does.That's what I was thinking. Don't know what is inside a berringer wheel, but I would NEVER tighten an axle nut with tapered roller bearings with anything but my fingers. Even a sealed bearing wouldn't be torqued in most circumstances.
Larry
My Beringer instructions indicate 220 lb-in for the axle nut.
I guess they changed the assy for the 14?
I would double check with Beringer on that torque just to be sure.
I agree. The nut is very narrow. I sent an email to Beringer and I'll report back what their latest position is. Maybe we'll get a new official fourth torque value! We've had 0, 141 and 220. Maybe 70 or 180in-lbs?The nut seems a little puny to torque that high? If you talk with Beringer can you post their response.
Update from Beringer, apparently the RV-10 and RV-14 mains are slightly different. The 10 main axle nut should remain finger tight and insert cotter pin. The 14 main axle nut should be torqued. Now to what torque since it has on one page (4/29) 140ish and another page (11/29) 220 in lbs. France engineering will review and update the document. Taking a guess at the outcome reviewing (5/7) M-00-005 Maintenance Working Card it will be 25 Nm or 221 in-lbs.I agree. The nut is very narrow. I sent an email to Beringer and I'll report back what their latest position is. Maybe we'll get a new official fourth torque value! We've had 0, 141 and 220. Maybe 70 or 180in-lbs?
I have always torqued to 220 and it is only a fraction of a turn after lightly tightening it. All the documents that I have had and watched a video from Beringer said 220 which is the same for the caliper bolts.Update from Beringer, apparently the RV-10 and RV-14 mains are slightly different. The 10 main axle nut should remain finger tight and insert cotter pin. The 14 main axle nut should be torqued. Now to what torque since it has on one page (4/29) 140ish and another page (11/29) 220 in lbs. France engineering will review and update the document. Taking a guess at the outcome reviewing (5/7) M-00-005 Maintenance Working Card it will be 25 Nm or 221 in-lbs.
They will also confirm the torque specs of the AN4 and AN6 nuts which seem high. Now need to find a deep socket to measure mine since I've been hand tightening for 6 years on the 14.![]()
Beringer publishes both 141 and 220 (See post #15).All the documents that I have had and watched a video from Beringer said 220 which is the same for the caliper bolts.
Did you find a 25 mm deep-deep socket, or did you go with 1 in. (25.4 mm) ?I have always torqued to 220 and it is only a fraction of a turn after lightly tightening it. All the documents that I have had and watched a video from Beringer said 220 which is the same for the caliper bolts.
I bought this crowfoot from Amazon and it was not expensive but it looks like they don't have the exact one anymore. This works perfectly. I am not at that hanger to check but pretty positive that is not 1" as I have another one that is 1" and use it for the oil filter.Did you find a 25 mm deep-deep socket, or did you go with 1 in. (25.4 mm) ?
It's 1 1/4"Did you find a 25 mm deep-deep socket, or did you go with 1 in. (25.4 mm) ?
Great tool. I have an 1 1/4" open/box wrench that works great. Gotta be careful as it is 1 1/2' long. Plenty of torque length.It's 1 1/4"
Thanks, it’s a 25 mm bolt with a 1 1/4 head. Should have known.It's 1 1/4"
I checked my record and last time I paid $31 for this crowfoot. We can see how prices have changed since, this is part of the reason flying is not as affordable anymore.I bought this crowfoot from Amazon and it was not expensive but it looks like they don't have the exact one anymore. This works perfectly. I am not at that hanger to check but pretty positive that is not 1" as I have another one that is 1" and use it for the oil filter.
Crows Foot Wrench, Fits Bullet Proof Diesel Hose Fittings 1-1/4"
This tool is specifically made to aid in the removal and installation of the 1 1/4-inch hoses and fittings on oil lines. Every tool chest needs one of these!bulletproofdiesel.com
