FORANE
I've been running NGK 3961 BR8ES plugs in my old plane with Titan X-340. They're inexpensive and I've been replacing them with new at condition inspection. That has worked well. Recently bought a new plane with IO-360 that has NGK 6619 iridium spark plugs. The iridiums are more expensive than the 3961's. I read the iridiums are good for much longer also. As such I'm considering not replacing at annual.
For those running iridium plugs, what is your plan at condition inspection? Do you simply reinstall the old so long as the engine monitor looks good? Do you test them for resistance, or with a spark plug tester? Do you replace with new at condition inspection?
